garysol wrote:
65ShelbyCobra wrote:
I know it doesn't pertain to the models you are interested in but I thought I'd throw this out there to all 31BH owners. I've slowly discovered/detected over the last few months, a potentially huge problem.
I had the same issue. I adjusted the door by moving those little hinge inserts just a smidgen and it has never been an issue since. Ill keep my fingers crossed.
It also happened to me a few times. The stab jacks at the back or the wheels might lower themselve into the ground with the weight applied after a day or two of camping and therefore the trailer is a bit unlevelled at the back or one one side of the trailer. Just relevel the jacks or what I found to be effective, is to put blocks (I use Lynx levelers) under the tires, mostly when one side is slightly lower than the other
