kainen wrote:
does any see a problem with running the AC for pretty much 24/7 and should we leave it on Auto ? or high during the day and put it to low at night ? What temp should we set it at 20 degrees celius ? Thanks in advance for your help.
That's a nice looking camper you have! We leave our AC on 24/7 when its summer time and we're camping. I assume the area you're going to be camping is dry. Just remember if it is humid (most often at night) then you need to keep the fan speed high and/or reduce temperature. If its to low of an air flow going across the coils that may cause them to freeze up. The air conditioners made today usually keep the inside about 20 degrees colder than the air is pulls in. So 100 degrees outside would expect at best to be about 80 degrees inside.
Enjoy your trip!
