gregrc75 wrote:
So far so good, only 2 issues so far that I have noticed. When we first hooked up to water I noticed a small puddle forming on the floor in the bedroom. I opened the panel above the water pump and simply tightened the fitting where the hose attaches. That stopped the leak.
The second issue I had was water seeping underneath the shower stall surround. I remember reading that other have had the same issue and I will recaulk the area to make it water tight.
The panel where the pump is located is a pain to get into. Why not just easy screws?? NOOOOO they had to use these star hex type things! Thank goodness we had something to use with us when we opened the area to just look to see what was down there. Wonder what others have there?
Our shower stall leaks in one area about a tablespoon of water but never anymore than that and it's never reached the floor. I understand where the doors and floor meet it is ok to caulk but the other areas are not caulked for air circulation. Let us know how that goes and what you use.
Sounds like you're off to a great start!
