garysol wrote:
So your saying that you did not have sewer hook up at the CG? Did you hook the flush hose up without draining your black tank first?
You mentioned that no water came out of the black tank with the hose on. Did you have the black tank valve open? Sorry for the questions just want to make sure I am understanding....
Correct. We had no sewer. So, prior to leaving the site, I filled the black tank up as much as I could (verify). Then I went to dump. Considering this was my first time, I dumped like normal, grey then black. I don't recall whether I left the black tank valve open or not, or even tried both to be honest. However, the hose that I was using to fill the tank had no connector - just the rubber portion of the hose. So, I placed it up against the inlet valve to see if water could at least get to the tank. Didn't see anything come out of the tank so it got me to wondering. I might try to hook up the flush tonight to a extra hose to see if I can get water in the tank. I'll be taking it to my permanent site over the next couple of weeks, so it'll be ok for a bit.
