65ShelbyCobra wrote:
garysol, I remember reading that some people have found their heater ducting that runs to the bunkhouse disconnected. That may be the reason that your bunkhouse was cold.
I think your thermostat may need adjusted for the issue of your camper being cold but it being set at 67. I have a temp thermocouple with my voltmeter and have checked the actual air temp with my thermo setting. Mine is within a couple degrees.
Good info. I may run out side and physically check the temp of the air coming out of the bunkhouse outlet. Not sure why I did not check that this morning......
