garysol wrote:
We had our final outing of the camping season this past weekend and had a little issue that I wanted to run by you guys. Last night was cold. Temps dropped down to the mid 30's. I had the thermostat set at 67 but when I awoke this morning my inside thermometer read 60 degrees and my furnace was not running. I had to raise the desired temp on my thermostat to 70 degrees before it would come on. My other problem I had was with how cold the bunk house got. It had to be a good 5 degrees colder (if not more) than the rest of the trailer. I guess ill have to stick a small heater in the back........
Do you have a digital thermostat? It made a big difference when I put my digital one in.
For the Bunkhouse being colder, mine was like that as well and I discovered the hose was disconnected at the furnace plenum for the rear vents, you may want to take the cover off below your fridge and make sure they are all connected good. Just so you know, my cover was attached with the square bit screws.
Edit- my bad, I started typing my response then came back a little later to finish...didn't mean to repeat...
