baunno wrote:
gregrc75 wrote:
I did two simple mods to my Premier 28RLPR. First was I replaced the white plastic slide on the back screen door with a clear set. The white plastic always seems to be right in my line of sight when sitting in the rockers in the back. The second mod was I placed the clip on gutter extensions on the short gutter spouts. Hopefully they will direct the water away to help minimize the black streaks!
Hi Greg, Where did you get the clear door slide?
and has anybody retrofitted the screens with clear plastic?
I added the clear slide and had to re-enforce the seal between the stationary clear panel and the slide as there is a pretty big gap. The stationary plastic is very flimsy and bows easily even though I cut it to fit the slot in the door frame. Must say, not very impressed with the quatility... So I took a coat hanger coated with white outer stuff and cut it to fit. Then I ground down the ends to fit in the slot and placed it in the slot outside where the foam seal meets the sliding panel. Still is funky but I do like the clear panels. Not sure I'd do this mod knowing how thin the replacement panel is so Caveat Emptor!
