LivingthedreamOH wrote:
carjocky wrote:
Anyone had their water pump want to keep going and not shutting off? I just had this problem this weekend. I check for leaks and I did not see any. Water pressure was good. It just didnt want to shut off all the time after you shut the water off. It also seemed to get worse as the water level in the tank got lower.
Our friends had this happen. Loose connection in the hose restricted water flow. Tightened ...pump stopped.
I will have to find the pump and take a look at it tonight. Thanks,
