carjocky wrote:
LivingthedreamOH wrote:
carjocky wrote:
Anyone had their water pump want to keep going and not shutting off? I just had this problem this weekend. I check for leaks and I did not see any. Water pressure was good. It just didnt want to shut off all the time after you shut the water off. It also seemed to get worse as the water level in the tank got lower.
Our friends had this happen. Loose connection in the hose restricted water flow. Tightened ...pump stopped.
I will have to find the pump and take a look at it tonight. Thanks,
Pump is in the compartment in front of the laundry chute. We didn't like the loudness of the pump, so I glued 1/2" styrofoam insulation on all sides of the box,put an old mousepad under the pump and wrapped all hoses with old socks that came in contact with anything. We've had our 28rlpr for 3 years now and just love it !!!!
