baunno wrote:
Lighting in the Pantry
This may have already been discussed in this forum and if it has my apologies so please guide me to the discussion.
As Premier owners we all know the pantry is dark. I often use a flashlight to find things and want to light it with LED rope lighting. I'd like to use a plunge switch to turn it on and off, like a refrigerator switch so when you open the door the lights come on. Has anybody done a mod similiar to this?
I figure I can tap power from in back of the microwave but it looks like I'll have to pull the frig to run the AC line to the cupboard I'm not keen on doing that...
Recommendations accepted!
I
think there is an outlet behind the fridge. If you take the vent cover off from the outside you could probably tap into it there and only have to run the wire through the wall of the fridge cavity and into the back of the pantry. It is the outlet that the fridge itself is plugged into. I am at work so I cannot check on my trailer to be sure!
