Would you mind sharing the item number for those LED lights?
Talking about the tub leaking out a little and stuff...
I've seen water on the floor of the bathroom below that plastic cover after the shower has been used several times, I just figured it was water running around the top edge of the tub and running down the outside in that corner since I'm a little nose high (and usually am so the AC drains off the back of the TT) yesterday I noticed it was worse but the outside of that corner wasn't wet so I got to looking. Both edges of the tub behind the surround tapers down and leaves a couple inches without the tub protruding up behind the surround. I sealed those sections with some silicon and had my flashlight looking around the edge of the tub where the surround meets the tub, in the front right I noticed some little pieces of plastic behind the surround in the corner so I used a screw driver to move those and saw the tub was cracked in that corner! So the water was on top of the tub running to that corner and through the crack/broken corner and down below the tub. The water could be seem seeping below the wall in the hallway where the tub meets the wall as well. So I squirted about a quarter tube of silicon under there and used a spatula to stick under there to squish the sealant into the crack. I removed that cover and I could see where it was broken and I could see the sealant squeezing through so I know I got it sealed good.
Just something to check for if anyone sees water on the floor and don't know exactly where it's coming from!
