While we were camping I started to notice that our fresh water tank would stay on 'full' for a long time, then drop from full to 2/3 to 1/2 very quickly. Then we started to run out of water right about when the monitor showed 1/3. It's tough to run out of water when you think you still have 10 gallons left. Anyway, I went under the trailer, removed a few of the screws holding up the underbelly and saw this. It looks like the 1/3 sensor is LEVEL with the hose that goes to the pump. It also looks like the Empty sensors is BELOW that hose. So even though I SHOW 1/3 tank, I can't empty it because the hose is a few inches from the bottom. Anyone else have this problem? Should I have the dealer reinstall the sensors, or is my tank bad?
