coobrey wrote:
While we were camping I started to notice that our fresh water tank would stay on 'full' for a long time, then drop from full to 2/3 to 1/2 very quickly. Then we started to run out of water right about when the monitor showed 1/3. It's tough to run out of water when you think you still have 10 gallons left. Anyway, I went under the trailer, removed a few of the screws holding up the underbelly and saw this. It looks like the 1/3 sensor is LEVEL with the hose that goes to the pump. It also looks like the Empty sensors is BELOW that hose. So even though I SHOW 1/3 tank, I can't empty it because the hose is a few inches from the bottom. Anyone else have this problem? Should I have the dealer reinstall the sensors, or is my tank bad?
I have an easy fix that I did on my last 2 trailers with the same water intake. 1- take hose off barbed fitting 2-unscrew barbed fitting. 3-buy about 2 ft of 1/2 clear hose and glue it to the inside of barbed fitting(it will fit inside) 4-punch a bunch of holes in the hose at other end(end that will lay on bottom of center of tank) 5-find a brass or stainless screw or bolt that will screw into same end to hold hose down on tank floor,not allow hose to float. ....finally reassembly and you WILL get all water from tank. Also add screen filter to inlet of pump.....done.
