I wonder what the original question was? BTW/According to the experts (Oprah) TTs should ride front end lower than rear by 1-3 inches depending on length. Most people level them.There’s no harm in having the hitch adjusted a bit low, other than for possible ground-clearance problems on speed bumps and the like. In fact, a slightly low hitch may help your towing stability. If the hitch is high, so the trailer seems to be dragging its tail, that can lead to increased sway. - See more at: http://www.trailerlife.com/trailer-how-to/trailer-tech/hitch-leveling/#sthash.rSQYBIYI.dpuf
