RavensFan24 wrote:
eastcoasthd wrote:
Finally got a chance to check things out in more detail.
Just as you said..... Matter of choosing the correct input on the TV. :S
All is well
Glad to hear it!
We had the same problem with ours. The dealer checked it out and couldn't get it to fail, and he showed it to me. We had the problem again later and figured there must be a loose connection.
After reading your posts, I figured I might as well check it out. Sure enough, when on component mode, a DVD will play, but in B&W. Switching to AV mode resulted in a clear color picture. THANKS FOLKS! I would have thought it would either work or not, wrong!
