kodiakcanuck
Mar 02, 2015Explorer
I have the same layout only in the Kodiak 240 KSSL version. The bed issue is fixed in the newer models as mentioned, so I find it huge and comfortable. Also the TV issue is fixed with the newer models as the bracket moves in mutiple direction so it can be seen from the dinnete, sofa or the master bed, also there is another hook up for a TV in the bunk area.
I will agree the bathroom is small, although at 6ft tall I have no problem with the shower. Also the set up does not allow for a private closed off bedroom as mentioned, so you will have to weigh that out for your decision. Also the kids eventually do grow out of the bunk area (my son is now 13 and 6ft 2, so he doesnt fit). I had no problem with the counter space, coming from a HTT, I was used to small counter space. There is tons of storage space in this trailer as mentioned. Also the hitch weight is pretty heavy with these trailers, I suppose to compensate for the rear and side slide weight. So although the trailer isnt that heavy (under 6000 lbs loaded) our unit requires at least a large V8 truck to tow it comfortably...
On the positive side as to why we choose it; we love how open and big the middle part of the trailer is, it feels much bigger and with the high ceilings, a very large trailer feeling.
Good luck.
Good luck.
