JCR-1
Mar 28, 2018Explorer
mike-s wrote:JCR-1 wrote:Try getting GM to honor a tire warranty. They cover what the warranty says they'll cover, just like Keystone. GM doesn't cover everything, nor does Keystone, which is up front about what's not covered:
Gm doesn't make the shocks , nor the radio, nor the thousands of parts installed on their vehicles however they fix them when they break and stand behind the warranty.Keystone Warranty wrote:The toilet is warranted by the toilet manufacturer.
THE LIMITED BASE AND STRUCTURAL WARRANTIES WILL NOT APPLY TO:..Equipment, products, components, appliances, or accessories not manufactured by Keystone
The only fault I can put on Keystone here is not explaining that properly when they were asked to cover it. A Dometic toilet should have a 2 year warranty, through Dometic. Edit: Oh, and that warranty doesn't cover labor.
B.S.. Gm replaced 4 tires for me under warranty.. due to mis alignment from the factory. It was not the tire's that were bad it was a misalignment from the factory. Also if you have a failed suspension comnponent that wore out the tires they would replace it if it was due to a manuf defect and not wear and tear.
