I was looking for suggestions on what kind of wood would make a light weight kitchen table. It has to be strong enough to hold up as a bed also. The first one I made is way to heavy to keep. Thanks
Most RV manufacturers use 3/4" MDF with formica type material glued to the top.
I would glue strips of hardwood (oak, cherry or maple) together and then shape it to fit your needs.
Once I used a hollow door to make a table. Hollow doors have a honeycomb inside made out of hard cardboard. They are lightweight but strong. You can cut it to fit and then add a wood strip to finish off the cut end. Only drawback is the thickness of the door.
