Mortimer_Brewst
Mar 18, 2016Explorer II
newman fulltimer wrote:
what rails are you talking about the slide is/supported from under with rails
I used to have a 2008 KZ 289 KS. The rear slides on KZ trailers use a cable system and slide on dual tracks which are attached to the ceiling.
If the tracks are that bad I would get new ones from KZ. I assume the screw holes are stripped. Were the tracks attached using every roof joist? How about filling the old holes in the ceiling with an epoxy filler and starting fresh. I think ours were attached with hex head screws. Perhaps a slightly larger screw? They have to be small enough to fit through the track slot and not interfere with the slide hardware though. Good luck!
