brholt
Feb 20, 2014Explorer II
travelnutz wrote:
The 1052 can be carried on a 3500 HD SRW truck safely and that's what Lance also recommends as a min. The COG is 48" and the heavy builtin items, 45 gallon FW tank, and about all storage areas inside the TC are forward of the DW COG point which is directly above the truck's rear wheels and that's an excellent design. That means most loaded cargo/liquid will share it's weight on the truck's front axles also instead of so much being behind thhe rear axle adding so much on the rear axle/tires.
This allows the NEW porch/storage optional bumper's 149 lbs to have minimal effect on the COG of the 3400+ lb TC. Common sense needs to be used in loading weighty items in the NEW porch/storage bumper if carried on a 3500 SRW truck even if the NEW bumper is rated for 600 lbs carrying capacity. No problem if on a 3500 DRW truck though!
The Lance 1191 model is a large TC and allows access to everything needed to be used with a slide in but it requires a 3500 DRW truck min which many truck/TC owners do NOT want. Perhaps, unless their truck is dedicated for the TC on only use and is what we feel also and hear constantly from fellow TC'ers. DRW's can be a REAL PIA around town etc as we know having
This really requires a DRW vehicle. From the TCM article: "The 2014 Lance 1052 is a hard-side, dry bath, double-slide truck camper for long bed trucks. The interior floor length of the Lance 1052 is 10'11” and the interior height is 6'9". Lance is reporting the dry weight of the Lance 1052 at 3,420 pounds without options and 3,987 pounds with standard build features; Ultra Deck Plus bumper, air conditioner, generator, convenience package, awning package, four season package, and roof rack."
At 4,000 lb dry weight before adding batteries, water, propane and stuff pushes it pretty firmly into DRW territory. Technically, if you had one battery, 10 lbs of propane, no water and no stuff you might be able to make it on a SRW but that is not really using a truck camper as a truck camper.
44,056 PostsLatest Activity: Jan 12, 2020
