DoneItAllExplorerAug 05, 2014Lance 1191 - New 110 Volt OutletI would like to install an additional 110 Volt outlet as indicated (on the step to the bunk. I am assuming that I can access 110 Volts behind my fuse panel, but I'm not sure where to tap in I'd like...Show More
Carb_CleanerExplorerAug 05, 2014They're commonly called "Goof Plates". Trust me, they're easy to find.
Related ContentLance 1191No power on outside GFCI outletAdding power outlets in slide with no wiringElectrical outlet issuesOutlet problem
