jmckelvy
Sep 06, 2016Explorer
brholt wrote:
I don't know what Lance does but my Arctic Fox came with:
- A wireless remote
- A long cablle. The wireless remote can be used a a "wired" remote and plugged in either to the activation switch behind the door to the dump valve compartment or directly into the jack controller up under the sink.
- A wired only emergency controller and short cable located by the jack controller panel under the sink that can be plugged into either location.
I really appreciated the emergency controller when I ran into a problem with the wireless controller. Turned out the controller front panel had gone bad (would activat a jack and not stop) and I had to send it in to get "bubble" switches replaced.
My AF990 came with the same. Plus you can manually crank the jacks with a 3/8 ratchet if all else fails.
The slideout also has a manual backup with crank.
