Buzzcut1
Jan 08, 2017Nomad II
harley4275 wrote:
sorry , but my lance had the 7 pin , but only used the clearance lights(tail) and pos and neg . As the truck brake and signal lights were visible at the rear. SIMPLY unhook the 6 pin and make it a 7 pin.
It should be easy to convert it to a regular 7 pin to connect to any truck . . you do not need to fill all the contacts. .
true but most 7 pins can't handle the 8ga hot wire that the lance connector can. faster charge for the batteries and you can run the fridge on DC if you wanted to.
