todsme
Nov 17, 2020Explorer
Lance campers R-value.
Have you noticed LANCE kind of skirts the issue of R-factor in their campers? Do you own a LANCE camper? Wood frame /aluminum skin,pre -2005 filon skin and Lancelock 2006 and later laminated walls are less than 3/4 of an inch thick.Vacuum bonded walls are solid, R-factor NO.does your LANCE say "FOAM COR" in entry door ,jam? If so you have a aluminum skinned camper (squire)That has laminated luan walls with an "ASTRO FOIL" overlay and ribbed aluminum exterior. Smooth wall LANCE campers did not have the "FOAM COR" option because of pressure laminating Filon skin to luan issues. Funny,, family friends squire stays a little cooler than are LANCE smooth skin 1140. We have owned Arctic Fox, Eagle Cap. Fit and finish ; not a LANCE. 2" walls,radius truss roof ..Yes.
