WoodGlue wrote:
When you can build a Travel Trailer with zero tolerance, that's saying something, that being why I'm such a fan of the CNC Router.
WoodGlue
I own a tool & die shop with CNC. The one thing that stood out for me was the claim of "zero tolerance." There is no such thing. That said, I believe they are cutting to a very acceptable tolerance.
The way they inset the framing into the foam seems to be very good, but how are the pieces joined? Are they welded, screwed or glued?
If they made a TT just a bit larger, with a much higher load capacity, I might consider one they build.
