4x4crazy's avatar
4x4crazy
Lance Lite 845 on F-250
I am looking at a 2001 Lance Lite 845 to go onto my 2017 F-250 (Crew cab, 4x4, diesel, short bed). I don't think my truck will have any problem. I may be towing at the same time up to 5000lbs with about a 400lb tongue weight. My dealer wants me to install Timbrens, torqlift frame mount and fast guns. Is this the preffered method?
The camper doesn't have power jacks but the owner uses a power drill. Its a bit older t 2001 but I think with the low price it will be good to start getting out and seeing more of what I want and how much this gets used.
Any opinions on set up or the Lance Lite 845?
  • Put a used 845 Lite on my new 2006 GMC 2500HD 13 years ago. Have put about 125K miles on the camper. Added airbags first, then Bilstein heavy duty shocks, then TorkLift Stableload spring gadgets. Ride seems fine to me. When fully loaded for long term travel, I'm just under the 9200 lb GVWR of my truck.
    Did upgrade my tires to the next larger size (265X75)after seeing wear in the OEM ones.
    I have the TorkLift frame mounts and the Fastgun hold downs and like them.
    Good luck.
  • The fastguns are quite pricey, I chose the springload XL one at half the price. Airbags are a softer ride than Timbrens, both will do just fine. Have fun. :)
  • Timbrens when set up right will have a gap before contacting the stops....so you get a OEM ride when empty. Timbren will work with you on getting the right suspension rate for your truck.
    I wouldn't buy anything till you load the camper and make a 10 mile or longer trip down the road....then decide if the rear suspension needs help.
  • Had an '05 845 on a '04 Ram 2500 4x4. It did need air bags but it handled it very well. I did no mods other than air bags to that setup.
