orourkmw's avatar
orourkmw
Lance TC - lithium - DC-DC charger question
I’ve just purchased a 2020 Lance 975 that will sit in my 2022 F350. I have to install the Lance 6-pin at the front of my bed. I will also replace the two 12V lead acid house batteries with one 200 ah LiFePO4. The Lance has a battery separator, which appears to be installed just upstream of the house batteries. I think I need a DC-DC charger to protect the 270A alternator (as well as to get charging benefits), and am considering 30A-40A. Lance specifies at least 8 gauge hot and ground wires from the truck to the 6-pin. I am thinking that to protect the alternator from a large current draw, ideally I should run 2 or 4 AWG wire from the truck battery all the way to the DC-DC, and back, and not connect to the 6-pin plug (so skip the 8 ga). I think CamperJeff explained the potential complications of feeding the 6-pin. I would mount the DC-DC at the battery box, which is ~4 foot from the pin connector, so I’ll have to see how to feed the wire through. My questions are these: First, am I understanding this properly? If I can keep the battery separator in-line and ahead of the DC-DC, can I avoid the D+ signal wire that the DC-DC uses to isolate truck from house? I think the DC-DC only takes as large as 6 ga, so I’ll need to narrow down as close to the end as I can manage. Is there still a risk of overheating when running lighter gauge wire between the relatively short run from the battery isolator through the DC-DC to the LiFePO4? Any guidance would be appreciated.
  • If your roof has sufficient space, solar would be easier. Another option is a AC to DC Lithium charger if your truck has a 120 volt plug that is hot when driving. Mine is a 10 amp charger.
