adamis's avatar
adamis
Nomad II
Dec 23, 2016
Solar Charger & Truck Power Question
I've recently installed a Go Power! GP-PWM-30 30 Amp Solar Regulator because the previous owner had solar installed but no charge controller (he just had a simple diode or voltage regulator that connected to the fridge power line which seemed pretty weird and ineffective). After installation, The GP-PWM unit gave me better insight to see what was happening with my batteries and I realized that my batteries had not been properly topped off while charging from the truck while driving like I assumed they would possibly because they were getting too many AMPS when they needed a trickle for top off.
I then purchased a trickle charger for when the truck and camper are in storage and that topped the batteries off nicely but now I realize that I also need a trickle charger for on the road. I don't want to purchase and wire another charge controller into the camper so I am considering wiring the truck power to run into my solar charge controller via the same terminals as the solar panel connects to. I would then install a toggle switch so that I could select my source to be either from the truck or the panel. The idea being that when I'm on the road, I set my switch to source power from the truck and the controller keeps the batteries topped off and then when camping, I toggle the switch to isolate the truck and camper and now power is coming from the solar panel.
Taking this idea one step further, my controller has the ability to monitor two battery banks so I'm considering wiring the 2nd battery bank to run back to the truck power line coming into the camper so that when parked and my source is set for the solar panel, the controller will charge both the camper batteries and keep the truck batteries topped off.
I know it's a bit confusing but, has anyone else done anything similar? Is there a reason I'm not thinking about for why I wouldn't want to do this?
