pitchExplorer IIApr 17, 2019Larger tiresHas anyone successfully upsized the 13" tires on a Jayco 23b to 14's? My research (such as it is) shows the 14's as needing an 1½ more space each. This would leave ¾ to 1" clearance between them. Is t...Show More
bob213ExplorerApr 17, 2019I believe (e Trailer) the recommended is 4 inches but Dexter says a minimum of 1" will work.
Related ContentLarger tires on F350Larger circumference tires better mileage?Speedo correction for larger tires?Bias ply vs. radial tiresLarger wheels
