Has anyone successfully upsized the 13" tires on a Jayco 23b to 14's? My research (such as it is) shows the 14's as needing an 1½ more space each. This would leave ¾ to 1" clearance between them. Is t...
If you have 175/80/13 now, consider upgrading to 185/80/13 in a load range D as I did. I gained a little height and about 250 pounds per tire of capacity
