Cecilt
May 14, 2013Explorer
Dman1Well, we'll just keep on going until it does fail. At least we can always crank it manually if need be. Anyone else out there with an LCI that has worked well for them? This will be my 4th summer. I'm sure there are some longer lasting ones out there?
Don't be so sure of that. When mine failed it would not even manually crank. The inner shaft just moved up and down(had to use bungee cords to keep it from falling out). I was extremly lucky that mine broke when I was disconnecting in the storage lot and it had not put enough pressure on the block before breaking. I was on the ball and was able to get the block out. Drove it to my dealer for replacement. LCI is junk. Plenty of posts on here to support this. If you want my spare LCI I'll sell it to you for $50 + shippping. Works but I don't trust it.
44,066 PostsLatest Activity: Mar 14, 2015
