DirtyOil
Sep 06, 2015Explorer
RobertRyan wrote:
of course there is no U.S. bumper tow capacities, :(they apply to the U.S. . So the max bumper tow capacity is 9,900lb,as shown for the Chevy DRW the legal Australian capacity for the. 6.7 . Go over that and your vehicle is impounded
RobertRyan wrote:
Payload capacity, meanwhile, is rated (seemingly conservatively) at 1100kg. As a comparison it's worth noting that a diesel-powered 4x4 dual-cab Ford Ranger is capable of towing 3500kg and has a payload of 1132kg
RobertRyan wrote:
Yes they are talking about 5th wheeler GCVWR, you require air brakes. Not US bumper tow capacities which is illegal
RobertRyan wrote:ShinerBock wrote:RobertRyan wrote:
A F150 can be driven on a car licence. A F250/ F350 can also be driven on a car licence.
Of course an F150/F250/350 can be driven on a car licence. Did you not read what i said above? They purposely downgrade their GVM so that be driven on a car licence.RobertRyan wrote:
U.S. tow Ratings are not acceptable
Actually according to Australian law the manufacturer's tow rating are acceptable up to 4.5 tonnes as long as you have the proper tow bar and electric brake which according to Performax all their import conversions have. After 4.5 tonne, the trailer must be equipped with air brakes therefore the truck must be equipped with an air brake kit. According to Performax, once this air brake kit is installed, then the vehicles can tow up to the 9 tonne max of the car license class if the manufacturer's tow rating for said vehicle allows it. I would email them if you have any questions about it. They were very helpful in answering all my questions.
Yes they are talking about 5th wheeler GCVWR,19,000lb. you require air brakes. Not US bumper tow capacities which are illegal
The centrepiece of the blue oval truck is a 6.7-litre turbo diesel V8 that churns out a hearty 328kW of power and 1166Nm of torque. Drive is sent all four wheels via a six-speed automatic – culminating in a maximum braked towing capacity of 4.5 tonnes (9, 900lbs) in Australia. Payload capacity, meanwhile, is rated (seemingly conservatively) at 1100kg. As a comparison it's worth noting that a diesel-powered 4x4 dual-cab Ford Ranger is capable of towing 3500kg and has a payload of 1132kg
GVM and licensing
In Australia, a car driver licence is limited to driving vehicles up to a maximum GVM of 4495 kg (9900 lb). Beyond this, a different class of licence is required. A vehicle with a GVM under 4495 kg is termed a light vehicle, while those over 4495 kg are termed heavy vehicles.
Many models of truck, for example F-Trucks, Silverado or GMC Sierra Denali, are manufactured to have a GVM rating of 5000 to 7000 kg (11,000 to 15,400 lb) but sold with the option of a GVM of just under 4495 kg so that they can be driven on a car licence. This is called a GVM downgrade.
As a government-approved provider, Performax International and its dealers may be able to assist with GVM downgrades on some vehicles to allow driving on a car licence. This is covered under state legislation, therefore differs from state-to-state.
You have probably been given the correct info re licence. Apparently if you are purchasing a new F350 you need to make sure it's de-rated to 4995kg GVM or you will have to get a light truck license to drive it and it will have to go through a machinery inspection every year like any other commercial truck. Probably no way around it with an F450
RobertRyan wrote:
European and Australian.ratings do not give US Pickups the same ratings as in the U.S., cuts both ways.
