Harlock's avatar
Harlock
Leak at grey tank outlet - advice wanted
There is a good dribble at the tank side of the outlet flange, it eventually fills up the corrugated plastic sheeting underneath the trailer with water. You can see some gasket material extruded out. (see arrow for actual leak point)
It looks like the flange threads are glued on with pipe cement, judging by the dribbles of solidified stuff coming out of the threads.
Can PVC pipe cement seal the leak from the outside? Should I apply a piece of pipe material and cement, or just the cement?
As a secondary thing, I now need to patch up the corrugated plastic I cut though. Maybe clean it and use duct tape? Not sure how long that would last.
