LITEPHIL wrote:
I believe it's a standard size and hangs from the frame of the trailer. I want to get an exact replacement. Guess I should have made that clear that I want to replace it since it looks to have been repaired before. Don't want a custom tank just a replacement tank. My 2007 Forest River toy hauler had an identical set up and I remember the drain hung pretty low on that trailer.
My question is, has anyone replaced their underbelly tank and if so, where did you find it? If it's $1,000 I'll repair it but if it's $250-300 I'll buy a new one.
Thanks!
I will make extremely loud and clear.
There may absolutely be no EXACT replacements unless it comes from your EXACT YR AND MODEL or trailer.
Even though the tanks "look" like they are "standard" they are often not exactly the same. Often the dimensions will be different in one or more directions enough to require you to make all kinds of modifications to your frame and hanging system.
RV manufacturers tend to change designs like folks change their shorts, when they cease production of a model or model yr any excess parts which do not fit the new model or model yr are sold off to third party surplus dealers. Manufacturer may only hold on to some parts for a short time just to deal with possible warranty issues.
If you really want to go down that road, contact the customer service department directly of your brand of RV, maybe you will find a sympathetic ear that will be willing to leap off the edge for you and find your old tank.
But in the mean time,
HERE is another place that will ORDER your tank by dimensions via third party manufacturers (notice RONCO is one of their manufacturers).
HERE is another supplier which may carry some "standard sizes" but the ones I looked at were all non flange rectangular tanks.
HERE is another RV tank place..
HERE is a web search using "rv replacement water tanks" as the search key words (search engines are your friend!).
But, I will say this, the "repair" that was done on your tank, may not have been "welded" or "welded" correctly. Lots of folks don't wish to spend money on a broken tank tend to take the cheapest route possible and attempt to use glues which often work for a short time and then fail.
