On my new trailer I have a leaking fitting. I have contacted the salesman, but wanted to see if any one had any fixes here. It appears the leak is on the fitting between the plastic tubing and male co...
Don't use regular worm clamps, they can loosen up. I found out the hard way. Home Depot has simple PEX clamp tool you can but with out breaking the bank, and the clamps. Buy the tool and a package of clamps, they are easy to install. You may find you need one late at night, and you will have them. Also get a good pair of side cutter to remove the old clamps.
