tmas's avatar
tmas
Leaking pipe
On my new trailer I have a leaking fitting. I have contacted the salesman, but wanted to see if any one had any fixes here. It appears the leak is on the fitting between the plastic tubing and male connector for the hot water.
  • I would cut out the fitting and replace with Sharkbite or Gatorbite.
    That white flex hose I would replace with a faucet supply line style fitting.
    Home Depot or Lowes has it all.
  • Cut the clamp. Make sure plastic is not cracked. Retighten with Teflon tape on threads. Install new SS hose clamp. I'd do both. Doesn't look like much thread holding fitting. If new dealer should fix it, but that might be more trouble than the 30 minutes it would take you to do it.
