BarneyS
May 09, 2016Nomad
When you press down slightly on the toilet pedal the slide or ball seal will open slightly which will alow liquid to leak out of the bowl. This will also happen if something is stuck in the groove of the slide or built up on the ball or rubber seal. Usually cleaning will solve the problem.
If you are pressing down on the pedal to get more water in the bowl, try lifting on the pedal. This is the usual way to open the water valve without opening the toilet bowl drain seal.
Barney
Barney
44,056 PostsLatest Activity: May 04, 2014
