danimal53
May 09, 2016Explorer
BarneyS wrote:
When you press down slightly on the toilet pedal the slide or ball seal will open slightly which will alow liquid to leak out of the bowl. This will also happen if something is stuck in the groove of the slide or built up on the ball or rubber seal. Usually cleaning will solve the problem.
If you are pressing down on the pedal to get more water in the bowl, try lifting on the pedal. This is the usual way to open the water valve without opening the toilet bowl drain seal.
Barney
instruction on the underside of the toilet lid say to press down about halfway to fill with water. After filling and releasing the pedal, the water slowly drains through. So it must be the seal or something stuck. It has always done this, and I bought it new so something probably wasn't seated correctly from the factory. I'll have to take a look at cleaning or re-seating the seal.
44,056 PostsLatest Activity: May 04, 2014
