dodge_guy
May 17, 2015Explorer II
Ok, on a few things.
Yes they are RGB.
They are the weatherproof ones.
The one strip I used has 3M adhesive on it.
I installed them yesterday. I scuffed the bottom of the awning/gutter track and used some 3M adhesion promoter to keep the strip on the channel. I did end up drilling a hole right below the gutter that goes right in the bedroom. It is behind the awning when rolled up so even sealed up it should never see moisture. I then ran the 12V from the bedroom light switch to power the LED's. I put the remote "eye" through the hole to the outside so I can use the remote outside the trailer I used some Dicor to fill and seal the hole and left a "drip loop" for any moisture to drip off of. I also left the LED connector outside so the strip is easily replaceable if needed, I put dialectic grease in the connector to keep it from corroding.
It turned out very nice.
I'll get some pics up later.
Yes they are RGB.
44,066 PostsLatest Activity: Oct 04, 2013
