ktmrfs
Sep 03, 2015Explorer III
mine was easy. the factory outside flood came in behind the microwave. pulled out the microwave, tapped into the 12v going to the existing light, put two spst switches above the microwave, on turns on the exisiting light, one the leds. ran a 12v run then through the kitchen cabinet and drilled a small hole at the end of the led strip into the cabinet and tappped into the 12V wire I had run.
Now the main outside switch as you walk into the trailer turns on the whichever I had selected on the switches above the microwave.
If you wanted either the existing or the LED, or say LED always and wanted to choose the existing as a second choice a SPDT switch would do that as well.
44,066 PostsLatest Activity: Oct 04, 2013
