AnEv942
Feb 19, 2015Nomad
2014 Id be calling camper manufacture. Most LEDS are not designed to be serviceable, built as unit. That said some can be without too much difficulty if fair with a soldering iron-hardest part is identify LED used. That you could take the lens off to expose board..um.
Unless..there are a few T10 LEDs that plug in like a standard glass incandescant bulb, built on board usually used as a replacement, the base is the circuit board, they just unplug. Im hesitant thats what you have (dont start yanking) as most newer LED fixtures are hardwired, most replacement type bulbs use plastic base. Pictures would help...but first Id call camper mfg.
44,068 PostsLatest Activity: Jun 17, 2026
