joeshmoe
Feb 19, 2015Explorer III
Yep. You'll be removing the entire fixture (sealant and all), cutting the wires, installing new connectors and resealing. Only to do it again at some point in the not-too-distant future. The board and LED are one piece. It an absolutely ridiculous choice for a light sealed to the camper. Low cost, I guess. Unless you're in a pinch like I was, do not replace it a the same kind. Instead use a fixture with a replaceable inc or LED bulb. There's a catch though...unless you can find a longer fixture with a wider bolt center spread, you need to find fixtures with a 3" center mounting point as that is the distance between the existing bolt hole centers in the camper.
Don't waste time taking it to the dealer for warranty work. They'll just put the same******back on.
44,068 PostsLatest Activity: Jun 17, 2026
