joeshmoe
Feb 20, 2015Explorer III
I'll also be checking the wiring on the inside to see if there is another reason two of the three middle ones are not lit. Anyone with experience chasing the wires up thru the driver side ward in a WC 850?
The circuit board likely got wet since they aren't sealed for jack squat. I drilled tiny drain holes in the bottom of the rest of the light lenses. Going down the road will hopefully create a vacuum and keep them empty. I'll replace them as they burn out. Not going gonna with doing them all at once.
44,068 PostsLatest Activity: Jun 17, 2026
