boulderado's avatar
boulderado
LED replacement bulbs for Keystone Hideout
Does anyone know what type bulbs would be used in our light fixtures, they all seem the same (flat automotive type bulbs)? I am not close to the trailer to check at the moment, but I am looking for suitable LED replacements. Any educated guesses and recommendations on a good LED replacement would be appreciated. Thx.
  • You will have to get one out of the trailer and check which one it is.
    There are a couple of different styles.I got some like another poster had off ebay.Got the panel style for our truck camper as well.Sure use a lot less power.We got warm white.Just type the style of light bulb and led into the ebay search feature,Or if you want to spend more money go the the rv place.Do not if there is a quality difference as mine work fine.Get at least 24 led in the bulb if you can.If you look it up as a RV bulb you can get different shade of light. Bright white, warm white etc.
  • frisco_dave wrote:
    I know you know this, but...someone with a Keystone will need to reply. There's several different styles that could be used. "One" of those styles is what AirForceAngler posted- the 921 "flat" end. I have the same 921 in my KZ that I just upgraded to LED.
    But again...more than several styles, so it all really depends on what Keystone has chosen to go with.
    X2
    You may even have a couple of different bulbs. My TT has 2 different fixtures and each uses a different bulb.
  • I know you know this, but...someone with a Keystone will need to reply. There's several different styles that could be used. "One" of those styles is what AirForceAngler posted- the 921 "flat" end. I have the same 921 in my KZ that I just upgraded to LED.
  • Ivylog's avatar
    Ivylog
    Explorer III
    A 1156 is a common trailer light bulb and there are a few on Ebay.
