JoeChiOhki
Mar 26, 2021Explorer II
joeshmoe wrote:Geewizard wrote:
I've used these and have good luck in all areas of the TC and trailer.
https://www.superbrightleds.com/cat/rv-led-lights/?campaign=BING%20-%20RV%20Lighting&adgroup=RV%20%26%20Camper&msclkid=35fe6186f7fd1216aa2e01df1fff317d&utm_source=bing&utm_medium=cpc&utm_campaign=BING%20-%20RV%20Lighting&utm_term=rv%20lights&utm_content=RV%20%26%20Camper
This^^
I buy all my LED's and lighting stuff from them. Going on 7 years since my first purchase. Installed everything from curbside lighting for the camper to interior and exterior lighting on all my vehicles. Not a single failure compared to the cheap, China Ebay and Amazon LED's which I purchased about the same time. All those either completely or partially failed within 6 mos to a couple years. Don't bother with cheapo stuff.
I also used Phillips and Sylvania brand LEDS's for both the reading lights in the camper and for turn, tail and brake lights on some other vehicles. No complaints, but they are pricier.
Thank you :).
Installed the first fixture last night, the units use a 1016 base on the single bulb units as they have a "High and Low" mode on switch, so been looking at 1016 and 1157 for replacement LEDS.
I was wondering if Superbright was legit, but the fact that others have used it here with no ill effect lends more credence to it being a safe place to shop, so I'll be looking into replacement bulbs there, as the stock incandescent bulbs are fairly dim, even on high mode :p
