The bracket itself looks like it is twisted.
But there is obviously damage to the camper structure behind it as well.
You need to take the jack and bracket off and do some dissembly to see how much damage there is.
That can range from some splintered wood where the screws were pulled out to very bad wood rot.
The state of the screws will give you a hint. If they are very rusty, you are looking at a major problem.
But without disassembling first you can not do any repairs. It is not complicated. The corner moldings are held on with screws, the camper siding comes in sheets that are stapled to the camper frame at their lower edge. All of it is held together by butyl tape and sealant. Not very pleasant work to clean it all off, but a good set of screwdrivers gets you pretty far. Work from bottom to top.
The lower jack bracket has visible damage as well.
