I'm just about ready to pull the trigger on buying our next TT. Many that we've looked at had electric jacks to level the trailer however the one we have decided on does not. That is a feature that I ...
Yeah, the last thing you want to do is use your stabilizer jacks to lift your trailer off the ground. That will cause some bad problems down the road like 'krobbe' said. I have the Camco yellow interlocking blocks for leveling if/when needed. Use the 4 corner jacks to just keep the RV stable while you walk around in it.
