- covered_wagonExplorerDepending on how high your truck bed is sometimes it's easy to over extend the jacks and cause damage to them so putting wood 2x6's under the foot adds some lea way making it less likely to over extend them.
My 15 year old plastic ones, two packages of them, sometimes don't go high enough for level. They do get damaged sometimes without a pad or sink without a pad. If I was to do it over I would appreciate the wood blocks more since they have greater leveling ability/ more lift with each block. - Grit_dogNavigator III
BeMurda wrote:
I ordered the camco yellow block and shelled out for the rubber base.
Not the 7” tall one meant for trailer stab jacks I hope. That would be a good recipe for jack damage or camper tipping. - MORSNOWNavigator III
JRscooby wrote:
BeMurda wrote:
Ok since sliding is a concern should I use typical plastic blocks then? The truck camper is also going to be unloaded during winter and there may be some frozen moisture though I will clean it best I can.
If anyone can recommend a product I would appreciate it! Thanks!
Not sure plastic would be best idea, think I would want rubber. In my life, I would use mud flap or belting. Maybe floor mat. Grab a alligator off highway, cut to length.
Semi mudflaps are pretty inexpensive and can be cut with a razor knife or saw. I bought a couple for around $23.00 ea - BeMurdaExplorerI ordered the camco yellow block and shelled out for the rubber base.
- WarrenS65Explorer III put one of the stackable yellow plastic blocks under each jack. It flexes a bit so the entire jack foot can be in contact with the block and the block in contact with the concrete.
A 2% grade is pretty minimal. Just use the jacks to level it or have the front a bit higher than the back.
If you're storing it for a long time, I would support the belly as well, but it's not really necessary. - Grit_dogNavigator III
BeMurda wrote:
It's funny you all say that you n need to support the base with something under it when the 2010 Lance instruction manual specifically says not to do that?
You don’t need to support the bottom of the camper, in general. Only thing to watch for is if full tanks look pregnant under the camper. In which case supporting them or fixing the existing installation is a good idea.
If it’s going to sit there for a while it’s far more convenient and also more stable to just lower it down close to the ground. But again not totally necessary unless very nasty winds or actually “camping” in it.
Merry Christmas! And congrats on the belated Xmas present! - Grit_dogNavigator III
I wouldn’t put a single thing down. Maybe use some boards or little pieces of plywood. You’ll want something anyway for later if you’re unloading it on dirt somewhere while camping. But on the driveway the only thing they will do is prevent rust stains on the concrete.
Provided your driveway is actually only about 2deg or 4% grade.
If much steeper or the feet don’t appear to sit flat, then I’d consider wedging the feet to not point load one end of each foot.
Once you’re camping you’ll want some blocks to level up the truck when you’re camping w camper on the truck. But unlike some, I realize that was not your current question.
I’ve never bought the plastic Lego blocks for any of our campers. Guess it’s just too easy to cut up some scrap lumber. And if you lose them, crack the boards or just need some kindling wood for a campfire, they burn much nicer than plastic! Lol
You have to weed through some of the responses here as you’re finding out. Apparently there’s a lot of weird theories, paranoia and superstition surrounding campers as evidenced by some of the conversations even just in your threads you’ve started. - JRscoobyExplorer II
Not sure plastic would be best idea, think I would want rubber. In my life, I would use mud flap or belting. Maybe floor mat. Grab a alligator off highway, cut to length. - JimK-NYExplorer II
Read the manual again. It says not to use "tall" supports to store the camper in the "raised" position. The camper should be lowered close to the ground. In theory it is not necessary to use any supports since the jacks should carry the load. I still think it is a good idea to further support the camper. Then there is no issue if a jack fails or Spring rolls around and you find it necessary to replace or work on jack that is no longer working. Maybe I am just extra cautious because I have had jacks fail. - BeMurdaExplorerIt's funny you all say that you n need to support the base with something under it when the 2010 Lance instruction manual specifically says not to do that?
44,054 PostsLatest Activity: Dec 18, 2025
