rainy029's avatar
rainy029
Light Switch above sink and stove
We just purchased a 1992 Chateau privately. We are coming from a pop-up camper so don't know all the ins and out yet.. Inside of the camper there is a single black switch that turns red when flipped. The switch is beside the window above the sink and stove area. Camper is in storage right now so can't get pics till this weekend. Does anyone know what this switch is for? We can't seem to figure out what it goes to.
  • That is a description of our water pump switch. Put some water in the fresh water tank, turn it on, and open a faucet. Should start running. It will actually most likely start running before you open a faucet because it will be pressurizing the lines.
    Depending on how your rig is plumbed or if you have a winterizing kit installed, you may have to open a valve from the outlet side of the pump first. OR there may be a valve that needs opening on the inlet side of the pump from the water tank.
    On our trailer the water heater switch is in the same area but is a two position switch. One side puts the heater in electric mode, the other side in gas mode.
    It might help if you put that information in a signature. You would be amazed at the number of members who may have the exact same rig and can answer your questions for sure.:)
    Almost forgot. Welcome to the forums! :)
    Barney
