- BubbaChrisExplorerF150 and 30-foot trailer will not likely work as a combo. You'll run out of payload with tongue-weight plus all your stuff for full-timing.
Maintenance will also play a big factor into how the TT holds up. If you're handy and stay on top of things, anything will last longer than a neglected big-bucks unit. - BumpyroadExplorer
Terryallan wrote:
Bumpyroad wrote:
I'd never buy a 150 to full time with.
bumpy
But now. they are not even putting real motors in 250s so it is a mute point.
if the motors, brakes, suspension, tranny coolers, etc. are the same, then get a 350.
bumpy - TerryallanExplorer II
bumpy
But now. they are not even putting real motors in 250s so it is a mute point. - JiminDenverExplorer II
donn0128 wrote:
I understand boondocking. I understand full timing. I understand trying to keep cost down. What I dont understand is how your going to boondock for more than a coyple of days without more. Water propane and waste disposal are three major questions you need to addtess to yourself
We boondock for up to two weeks at a time and then have to move. While on the move we dump and refill. - JiminDenverExplorer IIWe use a ultra light for boondocking and it has held up well considering how rough the trails and weather is up there.
- 69_AvionExplorer
bumpy
Probably good advice. - BumpyroadExplorerI'd never buy a 150 to full time with.
bumpy - donn0128Explorer III understand boondocking. I understand full timing. I understand trying to keep cost down. What I dont understand is how your going to boondock for more than a coyple of days without more. Water propane and waste disposal are three major questions you need to addtess to yourself
- bid_timeNomad IIIWeight has very little to do with longevity. It's more based upon engineering and quality. For instance, pound for pound some aluminum alloys are stronger then steel, but way more expensive; titanium even more so. Plywood sheating vs. polyethylene sheeting; polyethylene has 1/3 the weight but 4 times the cost. So the moral of the story is, how is it constructed to make it lighter.
- Ron3rdExplorer IIIWe've owned 2 lightweight trailers and they were great for boondocking. The only downside to the lightweights as they tend to have smaller holding tanks. Construction-wise they hold up fine as long as you get a decent trailer.
44,054 PostsLatest Activity: Dec 18, 2025
